hab nochwas gefunden
INPUTFW:DROP TCP (br0) ip-vom-client:52888 -> ip-von-der-endian:10443-MAC=xx:xx:xx:db:70:7a:bc:ae:c5:1e:95:3c:08:00 LEN=48 TOS=00 PREC=0x00 TTL=128 ID=6019 DF SEQ=4291907586 ACK=0 WINDOW=8192 SYN URGP=0 MARK=1800
Moin Leute,
ich habe der endian gestern vorm feierabend den befehl gegeben um 21:00 neu zu starten und als ich heute morgen zur arbeit gekommen bin war das web interface tot :o .
den httpd habe ich auch schon neugestartet aber hat nichts geändert.
Alex
hab gerade festgestellt das ich von aussen rankomme aber von innen gehts nicht :shock::?
also von grün auf webinteface geht nicht aber von rot geht :o
auszug aus dem httpd log von heute :
[Mon Feb 21 23:57:01 2011] [notice] Apache configured -- resuming normal operations
[Mon Feb 21 23:57:01 2011] [notice] Accept mutex: sysvsem (Default: sysvsem)
Use of uninitialized value in substitution (s///) at /home/httpd/html/proxy.pac line 154.
Use of uninitialized value in substitution (s///) at /home/httpd/html/proxy.pac line 157.
[Tue Feb 22 08:33:27 2011] [notice] caught SIGTERM, shutting down
Processing config directory: /etc/httpd/conf.d/*.conf
Processing config file: /etc/httpd/conf.d/emiproxy.conf
Processing config file: /etc/httpd/conf.d/initial-wizard.conf
Processing config file: /etc/httpd/conf.d/monit.conf
Processing config file: /etc/httpd/conf.d/notifications.conf
Processing config file: /etc/httpd/conf.d/sarg.conf
Processing config directory: /etc/httpd/conf.plain/*.conf
Processing config file: /etc/httpd/conf.plain/backupdeny.conf
Processing config file: /etc/httpd/conf.plain/proxypac.conf
Processing config directory: /etc/httpd/conf.d/vhosts/*.conf
[Tue Feb 22 08:33:27 2011] [notice] Digest: generating secret for digest authentication ...
[Tue Feb 22 08:33:27 2011] [notice] Digest: done
[Tue Feb 22 08:33:27 2011] [notice] Apache configured -- resuming normal operations
[Tue Feb 22 08:33:27 2011] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Tue Feb 22 08:35:02 2011] [notice] caught SIGTERM, shutting down
[Tue Feb 22 08:35:11 2011] [notice] Digest: generating secret for digest authentication ...
[Tue Feb 22 08:35:11 2011] [notice] Digest: done
[Tue Feb 22 08:35:11 2011] [notice] Apache configured -- resuming normal operations
[Tue Feb 22 08:35:11 2011] [notice] Accept mutex: sysvsem (Default: sysvsem)
auszug aus dem httpd log von gestern :
[Sun Feb 20 23:57:00 2011] [notice] Apache configured -- resuming normal operations
[Sun Feb 20 23:57:00 2011] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Mon Feb 21 21:00:08 2011] [notice] caught SIGTERM, shutting down
[Mon Feb 21 21:02:12 2011] [notice] Digest: generating secret for digest authentication ...
[Mon Feb 21 21:02:13 2011] [notice] Digest: done
[Mon Feb 21 21:02:13 2011] [notice] Apache configured -- resuming normal operations
[Mon Feb 21 21:02:13 2011] [notice] Accept mutex: sysvsem (Default: sysvsem)
Moin
Da fällt mir nur noch die möglichkeit ein, usb stick in die efw und inner console efw-backupusb eingeben.
gruß Alex
gut so
auf die 2.4.1 und 2.4 hab ich schon einen ganzschönen hass das aas schreibt mir vor welche radiosender ich hören darf ,
geht einen ganzschön auf den sack
gruß Alex
Hat funktioniert, Danke schön.
gruß Alex
hab da mal ne frage, gibs für die 2.4.1 schon ein workaroud zum dyndns update problem ?
ich bräuchte die funktion dringend.
gruß Alex
das selbe problem hatte ich hier auch mit einem openxchange und den eierphone(hoch lebe ANDROID ) vom chef und kollegen.
bei mir war die einfachste lösung bei host bearbeiten eintragen hostnamen: zxy, domain: dyndns.org,
und bei IP: die interne ip vom server und schon gings.
gruß Alex
ich auch nicht
im roten bereich also zwischen endian und cisco router ist nichts, dann sollte die endian sich was ziehen oder ist da vllt ein angriff im gange
naja werd mal nen wireshark rechner aufbauen
moin Leute,
ich möchte gerne mal wissen mit wen meine endian so viel zu quatschen hat.
intern kommt davon nix an.
schon komisch fast die ganze bandbreite ist verbraucht für was auch immer.
standleitung 2500kbit/s
Gruß Alex
moin
prozessor last war nichts auffälliges
speicher war auch nicht voll .
na ja ich werds mal nachverfolgen
Gruß Alex
hallo leute,
kann das sein das die 2.2 eine geschwindigkeits sperre ungefähr bei 4000KBit/s hat?
hab eine 2.2 aufgebaut mit proxy fw usw hw ist 1gb ram celeron 2Ghz
an ner 16000 inet leitung ohne endian gemessen 15300kbit/s mit endian 4000kbit/s
top bringt auch nichts auffälliges.
was kann das sein ?
gruß Alex
dein wort in gottes ohr momemtan ist es ja schlimm mit der 2.4.1.
gruß Alex
habt ihr alle gehört sabine iss versaut.
spass muss sein
gruß Alex
momentan ist die endian site auch nicht erreichbar na alles klar
moin ,
kann das sein das der dyndns updater nicht mehr geht nach dem update ?
kann das mal einer gegenprüfen.
gruß Alex
Zitat von "Denny Crane"
-War unter dem Reiter "System" eigentlich schon immer der Punkt "Web Console"?
nee ist mit dem update gekommen.
gruß Alex
Zitat von "smartiboy"evtl. blöde Frage, aber da es niemand erwähnt hat...
OpenVPN unter Windows 7 als Administrator gestartet ?Gruss
ja hatte ich in den eigenschaften der exe schon irgendwo angehakt.
Alex
ich habe es mal mit deiner config probiert aber wieder das selbe unter windows xp geht es under win7 gehts nicht.
entweder bin ich oder windows7 zu doof
efw ist eine 2.2 community
config:
client
dev tap
remote xxxxxxxxx.dyndns.org
port 1194
proto udp
ca cacert.pem
nobind
comp-lzo
persist-key
persist-tun
verb 3
auth-user-pass
fehlermeldung:
Wed Oct 13 13:36:39 2010 OpenVPN 2.1.3 i686-pc-mingw32 [SSL] [LZO2] [PKCS11] built on Aug 20 2010
Wed Oct 13 13:36:51 2010 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Oct 13 13:36:51 2010 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Oct 13 13:36:52 2010 LZO compression initialized
Wed Oct 13 13:36:52 2010 Control Channel MTU parms [ L:1574 D:138 EF:38 EB:0 ET:0 EL:0 ]
Wed Oct 13 13:36:52 2010 Socket Buffers: R=[8192->8192] S=[8192->8192]
Wed Oct 13 13:36:53 2010 Data Channel MTU parms [ L:1574 D:1450 EF:42 EB:135 ET:32 EL:0 AF:3/1 ]
Wed Oct 13 13:36:53 2010 Local Options hash (VER=V4): 'd79ca330'
Wed Oct 13 13:36:53 2010 Expected Remote Options hash (VER=V4): 'f7df56b8'
Wed Oct 13 13:36:53 2010 UDPv4 link local: [undef]
Wed Oct 13 13:36:53 2010 UDPv4 link remote: xxx.xxx.xxx.xxx:1194
Wed Oct 13 13:36:53 2010 TLS: Initial packet from xxx.xxx.xxx.xxx:1194, sid=bdb936dc d0b4db43
Wed Oct 13 13:36:53 2010 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Wed Oct 13 13:36:53 2010 VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: /C=IT/O=efw/CN=efw_CA
Wed Oct 13 13:36:53 2010 TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Wed Oct 13 13:36:53 2010 TLS Error: TLS object -> incoming plaintext read error
Wed Oct 13 13:36:53 2010 TLS Error: TLS handshake failed
Wed Oct 13 13:36:53 2010 TCP/UDP: Closing socket
Wed Oct 13 13:36:53 2010 SIGUSR1[soft,tls-error] received, process restarting
Wed Oct 13 13:36:53 2010 Restart pause, 2 second(s)
Wed Oct 13 13:36:55 2010 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Oct 13 13:36:55 2010 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Oct 13 13:36:55 2010 Re-using SSL/TLS context
Wed Oct 13 13:36:55 2010 LZO compression initialized
Wed Oct 13 13:36:55 2010 Control Channel MTU parms [ L:1574 D:138 EF:38 EB:0 ET:0 EL:0 ]
Wed Oct 13 13:36:55 2010 Socket Buffers: R=[8192->8192] S=[8192->8192]
Wed Oct 13 13:36:56 2010 Data Channel MTU parms [ L:1574 D:1450 EF:42 EB:135 ET:32 EL:0 AF:3/1 ]
Wed Oct 13 13:36:56 2010 Local Options hash (VER=V4): 'd79ca330'
Wed Oct 13 13:36:56 2010 Expected Remote Options hash (VER=V4): 'f7df56b8'
Wed Oct 13 13:36:56 2010 UDPv4 link local: [undef]
Wed Oct 13 13:36:56 2010 UDPv4 link remote: xxx.xxx.xxx.xxx:1194
Wed Oct 13 13:36:56 2010 TLS: Initial packet from xxx.xxx.xxx.xxx:1194, sid=049a1e0b 0557f7a2
Wed Oct 13 13:36:56 2010 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Wed Oct 13 13:36:56 2010 VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: /C=IT/O=efw/CN=efw_CA
Wed Oct 13 13:36:56 2010 TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Wed Oct 13 13:36:56 2010 TLS Error: TLS object -> incoming plaintext read error
Wed Oct 13 13:36:56 2010 TLS Error: TLS handshake failed
Wed Oct 13 13:36:56 2010 TCP/UDP: Closing socket
Wed Oct 13 13:36:56 2010 SIGUSR1[soft,tls-error] received, process restarting
Wed Oct 13 13:36:56 2010 Restart pause, 2 second(s)
also ich habe es hinbekommen den open vpn client im windows xp hinzubekommen mit diese konfig :
client
dev tap
;dev-node MyTap
;proto tcp
proto udp
remote xxx.xxx.xxx.xxx 1194
resolv-retry infinite
nobind
persist-key
persist-tun
;http-proxy-retry # retry on connection failures
;http-proxy [proxy server] [proxy port #]
;mute-replay-warnings
ca cacert.pem
auth-user-pass
;ns-cert-type server
;tls-auth ta.key 1
;cipher x
comp-lzo
verb 3
;mute 20
aber unter windoof7 funzt das nicht kommt immer fehlermeldung
Wed Oct 06 16:03:56 2010 OpenVPN 2.1.3 i686-pc-mingw32 [SSL] [LZO2] [PKCS11] built on Aug 20 2010
Wed Oct 06 16:04:07 2010 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Oct 06 16:04:07 2010 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Oct 06 16:04:09 2010 LZO compression initialized
Wed Oct 06 16:04:09 2010 Control Channel MTU parms [ L:1574 D:138 EF:38 EB:0 ET:0 EL:0 ]
Wed Oct 06 16:04:09 2010 Socket Buffers: R=[8192->8192] S=[8192->8192]
Wed Oct 06 16:04:09 2010 Data Channel MTU parms [ L:1574 D:1450 EF:42 EB:135 ET:32 EL:0 AF:3/1 ]
Wed Oct 06 16:04:09 2010 Local Options hash (VER=V4): 'd79ca330'
Wed Oct 06 16:04:09 2010 Expected Remote Options hash (VER=V4): 'f7df56b8'
Wed Oct 06 16:04:09 2010 UDPv4 link local: [undef]
Wed Oct 06 16:04:09 2010 UDPv4 link remote: xxx.xxx.xxx.xxx:1194
Wed Oct 06 16:04:09 2010 TLS: Initial packet from xxx.xxx.xxx.xxx:1194, sid=740db08f 85ab6269
Wed Oct 06 16:04:09 2010 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Wed Oct 06 16:04:10 2010 VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: /C=IT/O=efw/CN=efw_CA
Wed Oct 06 16:04:10 2010 TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Wed Oct 06 16:04:10 2010 TLS Error: TLS object -> incoming plaintext read error
Wed Oct 06 16:04:10 2010 TLS Error: TLS handshake failed
Wed Oct 06 16:04:10 2010 TCP/UDP: Closing socket
Wed Oct 06 16:04:10 2010 SIGUSR1[soft,tls-error] received, process restarting
Wed Oct 06 16:04:10 2010 Restart pause, 2 second(s)
Wed Oct 06 16:04:12 2010 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Oct 06 16:04:12 2010 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Oct 06 16:04:12 2010 Re-using SSL/TLS context
Wed Oct 06 16:04:12 2010 LZO compression initialized
Wed Oct 06 16:04:12 2010 Control Channel MTU parms [ L:1574 D:138 EF:38 EB:0 ET:0 EL:0 ]
Wed Oct 06 16:04:12 2010 Socket Buffers: R=[8192->8192] S=[8192->8192]
Wed Oct 06 16:04:24 2010 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Wed Oct 06 16:04:24 2010 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Wed Oct 06 16:04:24 2010 Re-using SSL/TLS context
Wed Oct 06 16:04:28 2010 TCP/UDP: Closing socket
Wed Oct 06 16:04:28 2010 SIGUSR1[soft,tls-error] received, process restarting
Wed Oct 06 16:04:28 2010 Restart pause, 2 second(s)
was mache ich falsch wie gesagt unter windows xp funzt es unter windwos7 kommt die fehlermeldung als client habe ich openvpn 2.1.3 genutzt und
mit dem securepoint vpn client habe ich es auch probiert.
securepoint client config :
client
comp-lzo
float
nobind
persist-key
persist-tun
auth-user-pass
dev tap
proto udp
ca "efw1.pem"
cert "efw1.pem"
key "efw1.pem"
ns-cert-type server
mssfix
route-method exe
verb 3
route-delay 2
remote-random
gruß Alex
muss irgendein problem mit dem ftp proxy sein
hatte aber noch keine zeit dem auf den grund zu gehen
